VB.NET help with classes
i am working on this transcript program for students.
i have a class called cSemester
on my form I need a bunch of semesters so i want to declare an array. The problem I am running into is that I can't delcare it properly.
dim sem(8) as cSemester
that will let me declare it. however, whenever i try to use any of the class's methods i get this error "Object reference not set to an instance of an object". So i then assumed its because i didn't create a new instance of the class by using the new keyword so i tried this
dim sem(8) as new cSemester
when i try to compile with that line it says "Arrays can not be declared with 'New'."
so my qestion is how do i declare an array of type cSemester?
Try/look into ReDim
You might be able to just ReDim or you might have to dim it with no array size and then ReDim it with the proper size.
if i declare it without an inital size
dim sem() as new cSemester
it still doesn't work because it is still an array. it just doesn't have an intial size. If i declare it as not an array i can't redim it because it isn't initially an array
CURSES to VB !!!!!
A couple of examples of instantiating an array of classes:
Code:
Module Module1
    Sub Main()
        Dim i As Integer
        Dim myArray1(5) As Foo
        For i = 0 To myArray1.GetUpperBound(0)
            myArray1(i) = New Foo(i)
        Next
        Dim myArray2() As Foo = New Foo() {New Foo(2), New Foo(4), New Foo(6)}
        show(myArray1)
        show(myArray2)
        Console.Read()
    End Sub
    Sub show(ByVal inArray As Foo())
        Dim i As Integer
        Console.WriteLine("Elements: {0}", inArray.GetUpperBound(0))
        For i = 0 To inArray.GetUpperBound(0)
            Console.Write("{0}  ", inArray(i).val)
        Next
        Console.WriteLine()
    End Sub
End Module
Class Foo
    Public val As Integer = 5
    Sub New(ByVal inVal As Integer)
        val = inVal
    End Sub
End Class
