VB.NET Array Question
PornFlake
I have two arrays name() and age(). I am using a DO WHILE loop to populate the two arrays. After the arrays are populated I am using a combo box to select name() and need to pass the () on to the age variable but I am not sure how to do that.
When I select an item in the combo box I know the value selected is correct as I can pass the variable name into a message box and it displays the correct selection. If I select an item in the fifth position I need to select the corresponding age() of the same position.
The array is being populated by reading a .txt file that contains the name, age in sequential order.
Anyone?
-Funk
SelectedIndex returns the selected index in the collection, SelectedItem returns the selected object in the collection. You obviously can't safely cast an Object to a numerical type in your situation.
How do I pass SelectedIndex to the second array? That is what I am confused about.
-Funk
Same way you're passing the value of the currently selected item to a MessageBox? Have any sample code?
Dim objReader As IO.StreamReader
Dim count As Integer
'Dim intFirstYearPopulation As Integer
If IO.File.Exists("c:\cities\cities.txt") = True Then
objReader = IO.File.OpenText("c:\cities\cities.txt")
Do While objReader.Peek <> -1
strCityName(count) = objReader.ReadLine()
decPopulation(count) = objReader.ReadLine()
cboCity.Items.Add(strCityName(count))
count += 1
Loop
Else
MsgBox("The file is not available. Restart the program when the file is available", , "Error")
Me.Close()
End If
End Sub
Private Sub btnComputeGrowth_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnComputeGrowth.Click
strSelectedItem = cboCity.SelectedItem
MsgBox(strSelectedItem)
These are declared as global:
Dim strCityName(9), strSelectedItem As String
Dim decPopulation(9) As Decimal
