VB Acript to delete reg key- ID
marty9876
[H]ard|DCer of the Month - February 2006
hkey_local_machine\sodtware\pandagroup\folding@home
anyone know how to write a little VB script action to delete this bugger?
I finally did it, forgot to delete this key on an image set...no wonder my CPU count is not moving.
I might get around to deleting it manually, upload a little VB double click would be cool. also be cool to include this in my sysprep run once deal to make sure this won't happen again....
Thanks!
Code:
Dim WshShell, bKey
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.RegDelete "HKLM\Software\PandeGroup\Folding@home\UserID"
Paste into notepad and save as blahblah.vbs . Use at your own risk of course.
I have no idea why the forum keeps putting spaces between foldi and ng. Remove those in notepad before you save it.
huh, I guess the a and s are next to each other on the keyboard too....
The software automatically breaks up long words to prevent them from causing the forum to scroll horizontally. So if I type a bunch of A's in a row, it will break them up on to multiple lines. However, it appears the setting is quite low - it should be somewhere around 80-100 characters, not 30.
12345678901234567890123456789012345678901234567890123456789012345678901234567890
Killer[MoB] said:
Code:
Dim WshShell, bKey
that limit shouldn't matter in the "CODE" tags...... they will scroll side-to-side and up-down independent of the forum......
Code:
Keep on Folding!! For the [H]orde!!
Thanks!
Marty,
I usually run -local in the command line so the machine ID is read from the client.cfg file instead of the registry.
