Hey everyone ive finally got around to building another rig after 4 years (thanks credit!!!) anyhow i am going to modify my case slightly with that some questions.
I will be working with this case.
http://www.dealsonic.com/skmssialatxm.html
My friend is going to cut the inside front to hold (2)80mm fans or (2)92MM fans
Gonna put to more fans on the side panel and change the back fan to something with a lil more omph.
My question however is I mentioned I wanted him to put a hole on the top so I could put another fan 120mm or something, he told me it was a stupid Idea because there would be a hotspot or deadspot or something spot (he bitches me out when I asked about a top fan)
So the question is will putting a top Fan on that case be a detriment?
and lastly my final question is in regards to a military switch ever since I saw this thing I wanted to put that on a case the problem I am having is I am told "By same friend" that putting a military switch is stupid and will be a bad idea because If I need to hold down the power button to power of the PC I wont have that option because its just a basic on and off switch.
So what I was wondering if I could use a military switch and somehow put a second push button somewhere on the system for if the problem arises and I need to hold down a button to shut down the case.
Any suggestions would be greatly appreciated.
