Various HTPC Questions...
Jaybird376
Hello everyone,
I've read a lot of the various threads and found them very helpful. I've just got a few questions related to my setup that I was hoping to get some input on.
I'm planning to setup a dual TV HTPC setup, using each TV as a monitor for external display. I've also got HD DirecTV that I'd want to display on one of the TVs at times.
That leaves me with a few questions:
1. How powerful a graphics card do I need to reliable output dual 1080 screens?
I'll be doing some gaming on the computer, mainly TF2 and likely Diablo3 / Starcraft2 when it comes out, as well as the obvious encoding / movie playing etc...
2. How do I configure the audio?
If I'm in dual-screen monitor mode, I'd want the audio going over HDMI to the receiver. That would get the audio outputing over the surround-sound speakers.
However, if I'm watching DirecTV, I'll need the HDMI from the DirecTV box to go to the receiver and carry audio to the speakers, since you can't pipe HD content (w/o some major hurdles) through the PC. In that scenario, I'd still want some audio from the PC to output over something, same speakers and or small set of pc speakers.
Can that even work? I'm confused how I would set that up.
3. Media Center Keyboard
Any recommendations? I've used the Microsoft Entertainment Series (7000) before and it's not too bad. The touch pad is a little slow to use, but it's a solid keyboard. I've heard good things about the DiNovo Edge, but I'm curious what people think about using it as a HTPC keyboard, particularly the touch pad.
Any help / thoughts would be greatly appreciated.
Thanks in advance,
Jaybird376
1. If you want a powerful enough card for TF2, Diablo 3 and Starcraft 2, then you're looking into an Ati Radeon HD4XXX series. Probably in the higher end. 48XX or higher. Since gaming you'll want to be nice, plus it will be powerful enough to drive dual monitors at high resolution.
2. Your audio will play whatever is producing sound. So if you're watching a movie that's 1080p then sound will play that despite whatever monitor you're on. If you're playing a game, same thing. If you try to do both at the same time, then you're probably gonna have some issues.
3. The Logitech Dinovo series is probably one of the best series to buy. Whether it's the DiNovo or DiNovo Mini, they are both great keyboards and the touchpad or touch wheel work very well. Me personally, I am not a fan of Microsoft products and will never buy one of their keyboards again, after having 3 of their bluetooth keyboards die on me while being use as HTPC keyboards. So I only use Logitech now for keyboards and mice.
4. I suggest a Logitech Harmony remote also. Whether it's the 880, 890 or even better, the Logitech Harmony One, you'll love it.
