Variable MCP655 Speed - Which Setting?
liquidfluidity
Which is better higher flow or lower flow for more time in the rad for cooling. I'm running a 2x120 and a 1 x120 in my loop which is only for my cpu. I know kind of strange set-up but it's what I had.:rolleyes: I have the variable Swiftech , a Fusion cpu block and a "T" line. All 1/2" high flow. What do you guys think?:confused:
I didn't find any decrease in temps (only increased noise) by moving mine up from 1.
MCR220, MCP655, Fuzion2, X38, MicroRes, 7/16" MasterKleer.
Thanks for the responses. I didn't really have a noise difference as one of my fans is kind of loud/high cfm. I guess I'll just leave it alone(3) until I do a little overclocking and see if there's any real difference between the settings.
