Originally posted by nst6563
Get both an awsome WC setup AND the Vapo/Prommy...then put a bit of antifreeze in the WC mix...and put the Vapo/Prommy on the water resevoir...that way you can cool CPU, NB, GPU with those ultra low temps
....anyone ever tried that???? Would it even work??? I would think so as long as the water was kept moving and had some antifreeze...but I could be wrong. Closest I've been to watercooling was pissing on an old Compaq EN.
for waterchillers, leave the prommie or the vapo entirely out of the plan and you'd be on the right track. a correctly built waterchiller with the right coolant is close to the best all around cooling system that you can get.
take a decent sized reservior with coolant rated for -50C or better and add a phase change system with an evaporator designed to chill a volume of liquid (as opposed to one designed for direct die cooling) and you have a cooling system that can subzero every major component on your system through a fairly standard (albeit heavily insulated) watercooling loop.
prommies or vapos only cool the CPU. to get cooling to the GPU or the n.bridge you have to 1).start from scratch (build a phase change system that will work properly with more than one evaporator - also referred to as a royal pain in the ass) 2). Add more phase change systems to cool the other components thru direct die cooling (better have a massive fricken case) 3). add pelts and water to other components (not as efficient as phase change)
you could use the same basic waterchiller design to go to extreme low temps (3M electronic liquids can work below -80C, they are dielectric and virtually nontoxic) or you can use a smaller compressor, condenser, different refrigerants, etc. and build a system that will only go down to 0C, 5C or just about any temp point you want....this could also be done with a very powerful system and a temp controller.
the good part - a waterchiller can be built much less than either of the direct die commercial models. If you already have a good H2O loop, you just have to insulate the hell out of everything and then hook it into the chiller.
no pre-existing H2O system? the cost is still much less.
complete H2O loop (with all the good gear) - $250
waterchiller - $150 max if you build your own.
total =$400.
side note: a prommie or vapo evap dunked into a res wouldn't work worth a damn - there is not enough surface area on the evap for the job at hand.
