cornelious0_0
- Apr 6, 2003
I was just wondering here, have any of you dismantled your LS to get the dimensions of the rad and compressor and all? The reason I'm asking is because next year I wanna be picking up the LS to show my 3.4E some lovin'...but instead of throwing it UNDER a case I had a better idea, just not sure if it'd work.
What I wanna do is pick up a Lian-Li V1200, mount my HDD in a 5.25" bay....and install the contents of the Vapochill LS in the bottom 2/3 of the case that are normally devoted to those two "sections" of hard drive rails.
The reason I wanna try and make it fit down there is I'm still gonna be leaving my NB and XT-PE on h2O.....and I wanna keep the Vapo out of the way if I can.....and fitting it in the bottom section of the V1200 seems like the best solution....if it'll fit.
I have yet to see anyone actually DO that.....but if I could get the length, width, and height of the different components in the LS and how much room they'd take up sitting side by side that'd be great.
I know that it shouldnt be too wide, as the Vapo can normally fit under a Lian-Li, which is 8" wide.....so as long as there's enough depth in the case (from front to back) and the lower HDD "section" between the front of the case and the PSU is tall enough I should be good to go.
Let me know what you guys think of the idea....and/or any measurements you can get for me.
EDIT: I just also realised that there's a gap in the V1200 getween those hard drive "cages" and the bottom 5.25" bay, so I guess if I really had to I could just completely cut out those hard drive cages and I figure then I WOULD be good to go.
I'd be cutting/adding my own window, but it wouldn't be hard at all to just have the window centrally located over the mobo...that way if I do completely cut out those HDD cages at the bottom you won't see the Vapochill just sittin there.
I was pretty sure that the Vapo and Prommies both used a single 120mm fan on their rads...so i figured that this way I could just mount the rad directly to the fron intake and turn it around to blow out the front of the case.
If I'm gonna cut out those "cages" I dont see any reason why it wouldn't work....but any input is still much appreciated.
