vapochill help
gijoe
Hi there,
This is my first post on these forums and its a hard one to start with :)
I know most of you are into building your own ,but to be honest i just dont have the time(and i have at least moters etc just laying around)
so i bought the vapochill ls and its great.
But like everything good or bad brings problems .So for the guys that built thiers great hope youll pass your help on,and for the guys that own them hope you might have an answer
Ok installed the system yesturday and bang first start -50 mobo came on fine around -15
Bit later in the evening i switched on and my ocz blow all my power boards on the floor out(tripped them)
Everything with the ls was no problem cooling still to -50 everything great but then the mobo wouldnt come on
Yep powerstream blown up tested it, its dead.
So i grab ther 24pin psu i have but its only 300w so i hooked that up to the mobo and circitsfor the vapo,the other 400w on the drives and the 6800s so theyed be able to run.
Ater that was all hooked up i turned everything on only to find that the mobo started to come to life but the vapo had both blue and red lights on the chill control and the front panel had nothing.
Remembering that the vapo would chill to -50 even when the other psu had blown
it just could get the mobo on with a blown psu now its been turned around.
If you have any ideas please let me know
the new psu will be here on tues looooog time to wait and the most imported thing being ,what does the red light mean?is something else blown now?
ok thanks for your time
hope to hear something for this neebie ls owner
best
joe
This is the thread i have going on bleedinedge
http://www.bleedinedge.com/forum/showthread.php?t=13919
Tbh the forums on vapochill themselves really leaves a hole(meaning nothing inside.
I hope someone might have and idea here and tonight i have tryed all the ideas given on be but still nothing.
Ive checked and re checked but same, but any way never know :)
Thanks in advance
joe
