Vantec UV Cold Cathode Problem...
PsychoSocket
Here is my quesion, I bought, today, a Vantec UV Cold Cathode light for my case. Everything was fine for about an hour until I noticed a very slight burning smell coming from the inverter that came with it. I looked closer and noticed a spark coming from inside the inverter periodically. I have no idea how an inverter works, so is this normal? Just in case I have turned the light off until I know what's going on.
Thanks.
I don't think that an inverter is supposed to spark....that's just begging for trouble. I would say that you have a bad inverter, bulb, or both.
RMA the kit just to be safe, and good luck.
-EPS
NOT normal. Get that sucker out of there. Check molex connections and stuff, run it outside the case for a while to check it further if you dare. Otherwise, return it!
Ok, thanks. I was going to return it anyway, just wanted to get the [H] opinion first. :p
Thanks
