- Feb 16, 2003
What kind of fan do you think will work better then an 80mm Vantec Tornado at cooling?
Is the 92mm Tornado going to make that much of a difference with my heatsink. The 80mm doesn't cover all of my heatsink so I was thinking I should probably get the 92mm so it would.
I'm getting use to the noise level.
