Hey guys.. I'm changing my HS/Fan to a SLK-948U and a 90-92mm fan.
I bought a Vantec Thermalflow 90mm and found out that its speed is automatically controlled by a thermal probe that is wired to the fan. Will this fan be okay for my use?? Has anyone else used this fan on a HS? Is there a way to make the fan work at 100% all the time?
Yes I will be overclocking.
