Vantec NexStar 3
hity645
Just bought one of these and I must say, this is really nice. My first impression was wow small! But I realized this would be a good thing for most users, to make it easier on carrying around. I bought the black one, which I think it makes no difference but after handling it for awhile the case got smudged up and you could easily see my finger prints all over it. Comes with a driver cd, manual and enough screws to get you going but no spares which made me wonder what to do in the even I lost one. The tray slides out easily enough but the small cable for the front led needs to be carefully moved out of the way our you'll pull it out. After that I slapped in an old 120 WD I have laying around already formatted to NTFS and has about 60gb worth of seinfield episodes. Install was simple, slap the drive in screw to tray reinsert trat, screw the tray to the case. Hook up the power/usb and turned it on. Windows detected it right away and opened up a new window where I was able to access and watch my seinfield episodes. Transfered about 2gb worth of images to the drive no problems. Though I am concerned about heat as this does not have a fan and it is quite noisy in a quiet room, but Im sure thats cause of the older drive. All in all its really nice, and if I need to Id buy another one.
