Vantec Iceberg HDD cooler
DeadlyAura
CoalWagen
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=211&products_id=3808
Thinking about picking a couple of these up for My HDDs to bring the temps down from 45*C but I wanted to check with you guys first.
Anybody used these before? If not, would you recommend I try them out?
I have used Vantec products in the past and like them alot and would consider these because they seem to be the best bang for my buck.
I'm looking for a cheap solution so I don't kill my WD800JD too quickly. :D
Front case fan blowing air through the drives is just as effective, for $0 (or close to it).
Well my Raidmax Cobra is the old style, instead of one 120mm fan in front, there are 4 80mm fans. So, I cant get one, ro even 2 fans, to blow on the drives, it blows more ont the edge of the cage. I don't want to put all 4 back in because it was loud as a bitch when I had them there.
I'm willing to spend the cash for a more quite yet effective method. Unless anyone has any mounting suggestions for fans.
Ah fuck it, I didn't have time to wait. I ordered them.
If they suck, I'll send them back. Would only cost the restocking fee. Which with $7 shipping and 15% of $20, It would be worth the try.
