Value for money 256gb ssd?
Beefcake
Hey there guys im trying to find the best value for money 256gb ssd to this date i have been doing lots of digging but most things are dated months ago so i was wondering if anyone had a more recent outlook hence my post
Thanks
Right now, I'd go with a 250GB Samsung 840 for $175 (if you are okay with TLC flash) or a 256GB Plextor M5S for $180 (if you prefer MLC flash). Those are the amazon prices at the moment.
chronos deluxe is $185 at newegg, M500 is $200, and extreme ii is $230. 840 pro is $10 more but not in stock.
personally I'd say get anything on the bottom of this curve, which is about 1000 seconds and below: http://anandtech.com/bench/SSD/263
anand likes the extreme ii because it is fast, even under heavy load and without extra space reserved. it has a 5 year warranty. and it is not the most expensive in its class.
PS: personally I think having more space than you need is more important than the ssd you get. if you will be bumping up against 240gb in a year, get one bigger IMO
Avoid Sandforce since you can get a Samsung 840 or Plextor M5S for the same or less.
The Extreme II is not a good value, since it is only 240GB for $230, whereas the Samsung 840 Pro is 256GB for $233, and the 840 Pro has better performance for all but the most extreme heavy write workloads. If you do have a very heavy write workload (I'd say fewer than 1% of purchasers would), you can always overprovision the 840 Pro down to 240GB and the performance should be similar to the Extreme II, except the 840 Pro has better 4K random read performance.
Extreme II is not sandforce but marvell. I am not how this performs, but I have used OWC Electra and sandisk ultra which uses sandforce controllers which are too good & I feel my money is worthy on them! chk this on your own guys
