VAIO Giga Pocket Software
Oldie
Mean Old Administrator
Sony has some TV software called Giga Pocket. I've got a friends computer, and I'm trying to solve an issue with it.
This error keeps poping up. I've installed the software update from Sony's website, over top of, and after removing the previous install. Can't find anything useful on Google, is anyone here familiar with this issue?
I don't get into OEM's much, so it's a first for me.
Thanks for looking!
Hi
If you didn't find anything on google for your specific problem, did you or your friend try contacting Sony support for the particular model?
I did a quick google myself and there do seem to be problems with that, but I didn't see anything identical to what you're getting.
Good luck!
It's out of warrenty, so calling them is a no-go, and there are zero on-line resources. There was an SP2 problem, but that's what the update was supposed to fix. I'm thinking something more recent broke it, I'm just wondering if someone else has seen it.
http://p200.ezboard.com/bunofficialsony
Vaio Village is a pretty good resource. In my experience Giga pocket is really sensitive when you start turning things off even remotely related to it on start up. If you shut anything off try turning anything that looks like it's related to it back on.
