Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Depends if you mean FALD or edge lit local dimming but there’s quite a few of each. The ASUs ROG Swift PG35VQ/ Acer x35 for instance with FALD. And the Asus XG438Q with edge lit for example.
There's a handful of 43" TVs too. Vizio's E43-F1 has 10 local dimming zones. Their 2019 model, 43" M quantum (M437-G0) has 12 local dimming zones. I believe they use VA panels.
I thought I saw Samsung had local dimming on a 2019 43" model but I can't find anything about it now.
If you care about good HDR, you want FALD. VA is fine for SDR content without local dimming but for HDR edge lit with limited zones doesn't produce that great results. If you can handle the size, TVs are your best bet in this regard.
There are no flat 16:9 displays with a VA-type panel and FALD under 49" in size, as far as I'm aware. You either have to settle for edge-lit (not recommended) or go ultrawide at that size for now.
With a 21:9 35" display you can pillarbox it to what is effectively a 28" 16:9 monitor.
