VA-10 Temperature sensors
Medieval
Does anyone know if these sensors on the Abit VA-10 mobo are accurate? I have two VA-10 Mobos, one with a 2100+ and the other a 2000+ CPU. Both of them report system (case) temps of 60 C and the CPU temp of 61 C or so **. I have another machine in the same room that reports the system temp as 30 C and CPU of 58 C (Abit NSF7 2.0 Mb - 3200+ CPU). This case is bigger and has two 120 mm fans in and wo 92 mm fans out for airflow. All CPUs are using the stock cooler.
I have tried adding fans to one of the VA-10 cases, that lowered the temps from a high of 72C (now thats hot! :eek: ) to the current 60C. It does sit in a small desk enclosure (room for air to exit via a good size hole). I do not like these temperatures, but wanted to make sure it was accurate before I tried to rectify the situation.
Thanks.
** On a side note all of these machines are under full load running either UD or F@H for the [H]orde.
