silverphoenix
- Feb 15, 2006
project Code name V2K-620
I started this worklog in XS so I'm copy pasting what I have so far.
Well I was inspired by disruptfam's V2000 Tri-loop. Originally I wanted to do what he did with some slight changes, but due to the MCR's being 8mm to wide they wouldn't fit on top of each other on the bottom. So instead I drew some inspiration from the TJ07 owners and decided to mount them side by side. Now I've jumped into so many projects before and ended up having some parts interfering or incompatibilities, so this time I'm taking my time before I order everything. I originally planned on ordering everything, but I found out that FrozenCpu is on the way from my home to my school, so I drove by them and picked up a bunch of stuff. I usually don't order from FZcpu because of the tax but by picking up in person I can make up the shipping costs.
So here are the basic rad mount plans, I may have posted these up before but this is the official log/WIP/watever. So far project is known as V2K 620, my main rig has always been called EOS.
I decided I'd have the radiators on the outside because they look better than the fans do, esp since the fan ribs would be facing outside.
here is list of parts so far
Actual PC hardware
-Q6600 G0 Have
-G.skill PC8000 2x2GB Have
-4x Maxtor 7200.10 320GB Have
-Abit IP35 Pro Have
-eVGA 8800GTS 320 SC Have(may step up to G92)
-Corsair HX620 Have
Case hardware
-Lian Li V2000 Have
-3 to 4 HDD converter Need to get (I may mod the original hdd holders)
-MNPCtech Black Rescessed handles Need to get
-Ac Ryan modders mesh or MNPC mesh?
-Need a decent priced laser or water jet cut or jig saw
Cooling Hardware
2x DDC3.2 with Petra Top Have 1
2x MCR320 Have 1
2x EK Res 250 Need to get
4x Bitspower Case Top Water Fill/ Through Hole Fitting Have
2x Bitspower Dual G1/4" High Flow Fitting - Male to Male Thread Have
10' Tygon R3603 7/16in. ID 5/8in need to get
1x Apoggee GTX w/ copper top have
1x MCW60 or EK full coverage block
6x Yate loon High spds
1x Sunbeam theta fan controller
I'll get better pix soon, windows resizer powertoy is great because I'm lazy but its algorithm sucks and picture quality goes down.
V2000 Plus(not plus II)
Now here is the surprise. I first saw these on PPC, and put them on my list because they were cheaper than DD fillport and male to male threads. And I have to say the quality is amazing, and they look amazing indeed.
Male - Male connector, any male connector has a captive O-ring very nice.
With a D-tek barb
My GTX which I painted the top black, after the 1st vinegar bath the nickel plating wasn't shiny. the brand new Copper top next to it.
About a year of use and no corrosion. The O-ring leaves a big black mark though.
GTX with copper top, gerdang this thing is twice as heavy now but it looks fantastic.
That's it for now, going to order more stuff tomorrow.
I decided it would be fun if I could ask a poll kind of question with each update.
For this one here it is. Should I jigsaw cut the window and holes for rad or find a water or laser cutting service? I wonder how much it would cost me.
So I got a quote back from the water/laser guy
He suggested laser as a more cost efficient method. Has anyone had their cases Laser cut?
Quote was for both panels. $120 about
Here is what I asked for, there are 2 vs of the 1st panel the quote is including lettering
I decided I'm going to pocket the money for laser cutting and use it elsewhere.
I figured since I have the vertical clearance I will mount the rads further back in the case. I didn't want to cut my window up top as big as the regular Lian Li windows as it show's the 5" bays. Instead I found out if I push the rad's as far back as possible the front part of the rads line up perfectly. So here is the revised plan so far.
Red is the radiator
green is pump location
Blue is cutouts
I made the bottom one larger than the rad so that when the rad's suck in air it can be blown out the top. Warmer air tends to rise so hopefully that will work out. The rear where the upper portion is blocked the air can escape via the 2 80mm holes in the back.
I also was browsing around when I stumbled upon ladderman's worklog. I figured I could drill out and tap the swiftech's just like him, the outermost walls don't have any tubes just fins. Here is what I plan on to brace the radiators. There will be cross braces ontop as well as on bottom, the bottom ones will have extra holes that can go through the LianLi holes and there will be small rubber washers to mount it.
Now I still need for the parts to come in as well as visit a place called fastenal to get some M3.5x20mm bolts.
I think I'm going to go buy some tools, I'm college and living in a private student apartment. I have some space in my room but not alot. I really want to get this 10" small drill press on sale at Harbor freight for $48, then I can measure drill and check the mounts. So much I want to do but I can't till everything is in haha.
Ok last question I originally planned to have the res setup like this.
But I'm wondering will it look better setup like this instead? side by side the other way?(again ladderman's pix)
P.S. Sorry for the ton of planning and questions and not much doing lol.(there will be much doing and pictures this weekend)
Actual PC hardware
-Q6600 G0 Have
-Abit IP35 Pro Have
-Corsair HX620 Have
Case hardware
-Lian Li V2000 Have
Cooling Hardware
2x MCR320 Have 1
With a D-tek barb
Red is the radiator
Blue is cutouts
