jetjaguar said:more for the silverstone so far ..
that is the only problem with the v series lian li .. is the btx .. btx is pretty much dead .. and for heatpipes on future motherboards .. this could be a problem ..
jetjaguar said:the v series cases by Lian li are btx
jnick said:I just wish the TJ07 had a version with a window on the side![]()
hacktor2 said:i'm pretty sure you can put a normal atx motherboard in the lian li cases even though they are btx.
Bugster said:It is sad that you wish such a thing in a case modding forum. Why not do it yourself?
0mega said:LiLi, and to those that argues about heatpipes, hes watercooling... it wont matter...
According to Asus, their chipset heatpipe coolers work in any configuration.JonDoms said:Yes you are rignt, you can put a ATX mobo on the Lian Li. But the newer Nforce 4 chipsets with heatpipes are not meant to be installed upside down, ala Lian Li.
sprocket said:According to Asus, their chipset heatpipe coolers work in any configuration.
