HI all,
I have just received my 2005fpw, but being newbish I'm confused.
My system is the following -
A8n-Sli Deluxe
Antec Smartpower 500W
Nec 3550a
Geforce 6200 DVI
1gb G-Skill Ram
Athlon 3500+ Venice
Case is a Delux with LCD Display
I bought from a company who had pre-built everything (i chose the parts) and I bought the PSU. I installed that last night and it went ok, except my wires are scrambled everywhere and look really messy. (How much of a problem is this?)
I stick the white DVI cable into the screen, and the slot on my case. I turn it on and select DVI-D with the menu selector. I get a screen, but then it goes off in 'Power-Save' Mode saying I should move the mouse or press keyboard, but this does nothing at this stage although they are plugged in.
So do I put in my windows xp disc?, the 2005fpw disc? the motheboard disc?
Ive tried them all but they make no difference,
I know this is really stupid and I'm being thick
But thanks in advance for all the help!
A8n-Sli Deluxe
Nec 3550a
Geforce 6200 DVI
1gb G-Skill Ram
Athlon 3500+ Venice
