I don't have much experience with setting up case lighting, especially UV lighting, but that's what I'm planning for my next build. I generally keep things relatively nondescript, but this time I'd like to learn about case lighting firsthand. I'd really appreciate a few pointers:
1. What's the best/brightest UV light source, and who is your favorite provider of them?
2. What is the best way to force UV reactivity--a brush-on, a spray, sleeving...?
3. Would it be possible to attach all lights in the case to a single switch (without having to wire my own circuits?) And if so could you make product-specific recommendations of a control that would work with a particular light's connector type?
I'll have plenty of room in the case, it's a Thermaltake Armor +. There will be a large GTX260 in the case as well as a Thermalright TRUE cooler. The fans will be all-black non-lit ones. The "point" of the design is to have a case that looks perfectly meh until you hit the switch and the whole thing lights up.
