UV inking my mobo/vidcard
Gongo
ok, so i think i want to get a UV pen and trace my mobo or vid card.. is there something i should be worried about? ie... something i shouldnt trace over because it kills the card/ mobo? as long as i dont penetrate the surface should i be ok? does this hurt the card in any way? and finally.. does it screw with heat transfer?
i've seen people litterly cover there boarsds on uv stuff (ink, paint, etc.) as long as th uv ink or paint isnt conductive you shouldnet have anything to worry about
