UV Dye recommendations
  • Thread starter Deleted member 134350
  • Start date
D
Guest
I have searched the forum and get conflicting info on which dyes if any are good. I would like to be able to add a few drops of a UV reactant dye to my loop as long as it won't hurt the loop or the loops performance. What are your recommendations?
Thanks...
Thanks, I decided on FrozenCPU blue uv dye.
