UT3 + SLI?!?!?!
The Cobra
Hi Folks,
Just thought I would pass this along. I recently purchased UT3 for the PC. I also installed the latest beta drivers for the 8800GTX series video card. It seems as though that SLI is indeed broken with UT3, along with other games that run on the Unreal 3 Engine. It was also like this with the demo of the game. I have read over at Guru3D and NVNews that some other people are having this problem. Does anyone here know of a work around?
Cheers,
Anthony
Broken how? My SLI seems to work fine, but I haven't tried it with one card. I'm running the latest beta drivers on XP64.
I know that doesn't help the problem. I have issues with SLI in Crysis and the only answer I got was, "It works fine for me!"
It runs fine for me, but I can tell you I don't run the newest beta driver. I run one that is about 3 versions old I think.
Also are you running XP or Vista? I am running Vista, so I didn't want to give you any advice if your not running the same OS.
