UT 2004 SP2 Computer restarts...
Xenozx
Not sure of where i should have put this but here is my problem. I have the system in my sig. I had regular windows SP1 installed. Everything was golden no problems at all really. Then i ran into some spyware i couldnt get rid of, backed up all my stuff and decided to reformat. After the reformat i installed SP1, then SP2, then Direct x 9.0c, then motherboard drivers, then videocard drivers 66.23 beta, then UT 2004. anyway the problem i have is this:
my computer will run fine in windows it will even run fine inside of UT 2004. The problem is when i try to exit UT 2004 my computer reboots. Now when im in window'ed mode of UT 2004 this problem does not exist. also i havent 100% confirmed this, but i think even when UT 2004 is full screen, i can alt+tab out of it without a problem. (im not home to check right now). any idea what could cause something like this? the only difference in my setup right now is SP2. I know its not an over heating problem. I even downclocked my overclock to see if it would go away to no avail. I havent tried any other games yet since this is the only one i have installed. I can probably install a demo and try it tonight worste case scenerio. Also it only seems to happen after you get into a game, if you full screen it and your in a menu, you can exit no problem i believe.
EDIT:
sorry one correction to the machine in my sig. I now have a MSI k8n neo 2 mobo. but again everything worked on this mobo before the reinstall of windows....
oh well problem fixed. I did 1 of 2 things that fixed it.
Powertoys for windows XP.
removed these
also uninstalled and reinstalled UT 2004. no longer reboots 8) FPS is much higher too, something must have been messed up...
happy happy joy joy, back to the ownage 8)
