Using USB devices with a VM and ESXi
AMD_Gamer
I learned how to use USB devices with your ESXi host/VM today. Very convenient. My boss needed some old files from a drive that we used with an older Buffalo TeraStation NAS that used the XFS file system. So i made a Ubuntu VM then added the USB controller and then added the USB device after it was attached to the host and it worked perfectly.:D
It would be cool if you could use USB devices remotely like have the vCenter Server/Client somehow use the USB device on the machine you are working from instead of having to attach the USB device to the physical host. I think that is how it works with remote FX?
:) It's an oft-requested feature, and VMware engineering is well aware of it :)
Suffice it to say, I'd expect to see it at some point ;)
