Hi,
Is it possible to use two different ATI video cards on the same PC, under Windows 7 ?
I don't mean Crossfire, but using them as two independent video cards.
What I have in mind is to get an ATI FirePro 2460 card, which will run 3 or 4 displays using Eyefinity, and at the same time have my Radeon HD 4850 video card on my second PCI-E x16 slot, driving my other monitor by itself only.
Will it work ?
I emailed ATI's technical support and they said that they didn't test it, and they don't recommend it because these are two different cards and drivers and it can cause problems.
This leads me to the other issue - if I'll install the moded FirePro drivers then the driver will treat the 4850 as a FirePro card so I won't have to install the Radeon drivers.
What do you think ?
Will it work ?
What do you think ?
