I want to connect 3 screens to my computer. I already have two connected to my 8800GTX, and I want to connect another. I have a Gigabyte P35-DS3 board, so only one real PCI-E slot (the other is a 2cm thing, not sure what that's about).
Anyway, I have an old PCI card - an ancient ATI 3D Rage II. I put it in the slot and loaded windows. It was the only working monitor at first and I had to extend the desktop to the other two. It didn't ask for drivers and worked perfectly.
The next time I started the computer, only the 3rd monitor lit up. When I tried adding the first two, I got an error:
"The display control panel is unable to change the display settings. You may not have appropriate administrative rights to change these settings."
When I click ok, I get another one -
"The display settings being saved are invalid. Please try a different combination of display settings."
And another -
"The currently selected graphics display driver can not be used. It was written for a previous version of windows, and is no longer compatible with this version of windows.
The system has been started using the default VGA driver.
Please contact your hardware manufacturer to get an upgraded driver, or select one of the microsoft provided drivers."
What the hell is up with that?
I tried looking for drivers for the card and installed a few, but none of them helped with this at all.
Any suggestions?
And another -
Any suggestions?
