Using SATA drive externally and sitting on PC case
Rikki
Hi folks,
Just got an F1 Samsung 1tb and am currently running it naked sitting on top of my PC case using the Gigabyte mobo's external SATA connectors.
Seems to work fine and dandy at the moment but I was wondering if running it sitting on the top of the PC case was good idea from an EMF standpoint as its right above the PSU.
The PC's in the corner so it isnt going to be knocked, or fall off so thats not a worry but having it perched right about the power supply is what I am currently wondering about.
Thanks folks,
Rik
Pfft I do it all the time when i'm messing with a system and havn't had any problems.
If it's a permanent arrangement then why not mount it inside, but it doesn't really matter.
Maybe just make sure there's nothing that could short out any exposed controller PCB on the back of the drive, and don't pile crap on top of it.
