Using one switch for power and reset
Chipicao
I was wondering if it's possible to use a single power switch (one typically found in any computer case) for both reset and power on. The idea is to connect both GND's at one end of the switch and the two "+" pins to the other end. Therefore a single press would reboot and holding for 4 seconds would turn off the system,
Has anyone tried this before, or does anybody know if it would work?
Probably depends on the mobo but I don't see why it wouldn't work.
Posted via [H] Mobile Device
Sounds like it could work. You seem to understand what you'd actually be doing by wiring it this way.
If you never need to use the momentary power button behaviour (ie. ACPI notification to the OS) and don't mind an immediate reboot or forced power off being your only options, that should work. You should only need to bring one ground to the switch, you only need to double up the sense pins.
Actually I don't need to shut down windows using the power button and I also don't mind the computer rebooting before powering off.
My biggest concern was that the motherboard might not like me connecting Power On "+" with Reset "+" and the "-" pins respectively, and I think it didn't. After a little testing my computer started to power down and then back on a few times, after which all BIOS settings were reset to their defaults and I couldn't change them. Not even clearing the CMOS would solve it, so I had to re-write the BIOS.
Then I realized that a typical PC switch has 2 sets of pins that are switched on or off at the same time but are not connected to each other, so basically it's just like pressing Power and Reset at the same time, only with one button.
