I would like to use ntune with my Asus A7N8X-E Deluxe, however for some reason when I load ntune I have no options, likely cause its not supported by default, in order to use the newer version of nvsystemutil I had to modify the nvsuoem.ini with the settings that came with the version that was included with my MB, works fine when I do that, but the nvsuoem.ini is different in ntune and I cant get it
Has anyone managed to get ntunel to operate on this MB (changing voltages etc) if so how did you do it, I've had no luck with asus's site, or if anyone has any ideas
