Ok, first off, i hope this is the right part of the forum for this question....
Ok so, I bought a new computer for my family.. but i didnt buy a floppy drive, not thinking about the fact that i need it for installing XP onto a sata hard drive.
So i went to google, searched about it.. and found i could use nLite to integrate the sata drivers into the xp installation... i found a couple guides... and followed three of them, but came to the same results with each! when i start up the computer, it starts the installation of windows, it shows on the bottom white bar that its loading all the files.. and then bam. i get the message "The file ahcix64.sys is corrupted."
ive followed the guides step by step... but am unable to get it.. any ideas?
my motherboard is a
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard
and the hard drive is
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
im trying to install Windows XP 32 bit
When burning the cd, i did use nLite to burn it... even though the guide said to use Nero, but i didnt think that would matter. Maybe it would, ill try that as well
my motherboard is a
