using my internal HDD to backup for format.
JonnyK
i've got some new hardware coming this week and i'm planning on buying a bigger hard drive than my two puny 60gb's and i don't really have a way to backup my files other than burning to dvd's, which takes a long time and costs money. so i was thinking i could move everything i wanted on to one of my hard drives and delete everything i don't need, take it out, format my new drive and 1 other 60, or both i suppose, not sure, and then use this http://www.newegg.com/Product/Product.asp?Item=N82E16812118401 to transfer my backed up files. would that cord work for what i want to do, connect an internal ide hard drive via usb to put files onto another drive? would windows pick up that external hard drive just fine? could i format that backup drive as well when i'm done using it and then use all 3 in my compy?
Any reason why you couldn't just have all three hard drives in your system at once and transfer the files you need over to the new drive?
would any problems arrise with me say, dragging files to the new hard drive now, taking it out, formatting the remaning drives, and putting it back in, distributing files, and leaving it? or would bad things happen.
Nope. I use rsync when I do that sort of mass filecopy, and run it twice to make sure that it transfers everything right. I know, I know, ecc this and redundant that, but I still copy&compare...
