Using multimeter to test MOBO
nuggetz
I think I fried my mobo. How exactly do I verify my PSU is throwing out the right voltage and additionally, can I test various parts of the mobo for power? I dont want to screw things up so if someone could tell me which pins, parts, or whatnot to touch, it would really help me get some piece of mind on what's broke. And maybe I may learn a thing or two. If anyone is interested, this is how my problems started:
http://hardforum.com/showthread.php?t=973518
placing your components into a known working test bed would be a good place to start. a process of elimination. if they all check out, then look to the board.
aside from replacing caps...there is not much you can do to repair a "fried" MoBo, unless you have the soldering equipment. a soldering iron or gun will cook your board, and due to the size and temperature of most home soldering wands/guns they damage a good number of surrounding traces/leads/trans/caps etc.
can you not RMA the board if it is determined to be the cause?
but if you are gonna try(and understand how to use a multimeter and what impedance is)...
a schematic would be most helpful. also you will need the manufacturers engineering specs for your board so you know what the tolerences are for you model and revision. you can of course follow the leads visually to locate where to position the contacts from a multi-meter, and see if you measure resistance.
it will likely be very time consuming, and magification is helpful in tracing leads in modern pcb's as they are quite small. depending on how many layers, you may not be able to take a visual assesment of the entire circuit(s). you need to know where they begin and terminate in order to measure a circuit.
i would place the board under magnification, and look for discoloration (due to burn etc) before trying to measure anything.
best of luck to ya.
Thanks for the reply but I guess I was thinking more along the lines of testing the pins in the 24pin connector or one of the molexs on my PSU to ensure that the voltages are what they're supposed to be. I'm pretty sure its the mobo at this point though. I couldn't have fried my PSU could I? Again, one of the molex connectors touched one of the 1394 pins on my mobo.
Choose a black wire for the minus input to the meter. The voltages for the other wires relative to the black ones should be:
+3.3v orange
+3.3v brown
+5.0v red
+12v yellow
-12v blue
+5v purple
-5v white
grey - about 5v
green - close to 0v
Note: if you can't turn the PSU on with the PC's power button... jumpering the green wire to a black one will force the PSU on.
you can fry a PSU, and Frank4d is correct on the PSU coonection. i also found a gif from a local (to me) vendors site regarding jupering a ATX PSU to power it on to test voltages etc...
if it aint broke... is a good policy.
ATX PSU power on
