orangedude
- Dec 30, 2012
Hi,
Here is my current system that I am planning to build:
Gigabyte Z77-D3H
1.5 TB WD 5400 RPM HD (This is from my old PC)
500 GB WD 5400 RPM HD (This is from my old PC)
I would like to add an SSD to improve the performance of my PC with every-day tasks.
The one thing I noticed about the Z77 board that I'm using is that it includes an mSATA slot which can be used for caching (Intel SMART).
Now my question is... if I buy a 256 GB mSATA SSD drive, can I partition it into 64 GB for the cache to speed up my HDD access times and leave the remaining 192 GB for OS and program installation?
Or would it be better to simply buy a 256 GB SATA III drive?
The price differential between the mSATA and SATA is not a concern (it's only ~$10 apart)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820148613 ($199)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820148443 ($189)
So basically, is this possible, and if so, how is the performance for these two setups comparatively?
Thanks
Gigabyte Z77-D3H
Thanks
