Using FLight Sim 04 with a 2005FPW
c0ex
I was wondoring if anyone here knows if Flight Simulator 2004 works with the widescreen moniter? Also does halo1 for pc work with widescree as well?
Thx
Ryan
Did you have to change any files or do you go into the settings-Display and then change the screen display settings to what?
no you dont need to change anything
just change your resolutions in the hardware section to 1920 x 1200
i have a 6600GT card and it runs fine with this card.
What res should i change it to for the 2005FPW? Should I change to the screen size as you said?
Also can u see the whole virtual cockpit ?
