Using FlashMenu on IS7...safe?
I have an IS7 with BIOS 17 and was wanting to flash it up to BIOS 20. I've heard some horror stories on P4P800 about the Windows based flash utility. I was wondering if anyone had flashed the IS7 with the FlashMenu, and if so, did you have to clear the CMOS?
I have used the windows Util on my IC7-Max2. Not the same but still an ABiT.
If your system is stable, and you have it on a UPS, then it is less of a risk to flash it from windows.
If there is a chance you will crash mid flash, then go to dos and do it oldskool.
==>Lazn
