Using external HDD as internal. Format stuck. Did I kill the drive?
cryodream
I have 8 Seagate FreeAgent GoFlex 3TB STAC3000102 external drives. I wanted to get the drives out of the enclosures and use them as internal drives. The actual hard drives inside are Seagate Barracuda ST3000DM001 3TB.
4-3 days ago, I took 3 of the drives out of their enclosures and tried using one of them inside my pc as internal. After windows started, I got a message that the drive needs to be formatted. I actually panicked, that I am gonna loose all my data inside (about 2TB of files inside that drive), so canceled the format mesage and shut windows down. I connected the drive back as external via original enclosure and was relieved to see not format message - drive ws ok and all files intact.
Now here comes the part where I probably f****ed it up. I remembered, that simply connecting the drives as internal does not work without the formating, so I did these steps with other 2 dives:
1. I moved all the files, to empty the drives.
2. I did a quick format on both drives, while they were still connected as external drives. I have a feeling, that this was the point where I screw up. I was in a hurry, I was not paying attention. Simply did a fast quick format on both drives and then windows shutdown.
3. I connected the drives as internal.
4. After windows start, I still got the message I need to format the drives. I canceled the popup.
5. I went into Disk Management to format the drives.
6. Now I noticed that the drives were messed up. It seems the drives were MBR, not GPT. My quick formats in previous steps did some weird crap. Each drives had 1 formated RAW partition of ~350GB and 2 other unallocated partitions. Huh. Each drive had 3 partitions.
7. I deleted all partitions.
8. Converted the drives to GPT.
9. Started a format on one of the drives. Once again I was too quick and not paying attention. I went through format wizard like a wind: next, next, next, using the default settings. Except, I did a proper long format this time, not quick. As it takes a long time to format a 3TB drive, I left it be.
10. After an hour or so I checked Disk Management and noticed that it showed the disk File System as RAW. Here I got a bad feeling and regretted not paying attention. I did not want to cancel the format in a middle, so I left it to finish.
11. Format process got stuck on 100%. It did not finish up. I waited for 12 hours, still stuck on 100%. Now the panic kicked in.
12. I tried to shutdown windows. Now windows is stuck on Shutting Down... screen for 2 hours.
13. I banged my head on the wall for being so stupid and not paying attention to what I'm doing.
14. I decided to ask for help on what should I do now.
Please help. What should I do? Did I actually kill the drive? Can the drive be fixed?
I know, this was so stupid of me, I guess it just was one of those days.
If you need any other info, please let me know.
Thanks in advance for any help.
If you are referring to windows support of drives larger than 2TB, here are the related specs:
OS: Windows 7 x64
Mobo: Supermicro X9SCM-F-O
HDDs: I already have 5x WD Red 3TB WD30EFRX working perfectly fine in this machine.
So, I am not an expert in all this, but I assume my system supports larger than 2TB drives with no problem? Well, I had no trouble with the new WD Reds, I simply set them to GPT and formated as NTFS. Working flawlessly. Or am I missing something?
What should I do?
I was thinking of booting to Seatools for dos and testing the drive. Could I format the drives in Seatools dos?
I was meaning you should download Diskwizard 13 and see if it can help you out.
You didn't kill the drive by just clicking around, don't worry.
