I've read many articles and plans about using diodes to drop voltage to control fans.
Everything I've seen refrences the 1n4001 which is rated at 1amp and provides about a .75v drop.
So how would I handle loads greater then 1amp? (Thinking WC pump)
Would wiring two in parallel do the trick, or is there a better diode to use?
