Using DFI FRONTX w/X-Fi
computergeek22
As simple as the title, can I use the headphone jack with the DFI Frontx with my X-Fi. If so, which pins do I plug in my frontx plug into on the soundcard?
I have an earlier version of FrontX that came with my DFI NF2 mobo. It doesn't have the extra 1/8" stereo cable. The connecter is one of those socket-pin kind of things similar to HDD/Power case light plugs that you plug into the mobo.As i'm goign to upgrade anyway to a new comp, my P180 has the same sort of plug as my current FrontX and i was concerned whether it would work or not. Is there any way to use those front audio ports on the case?
