I asked this elsewhere but no one figured out an answer... So I understand the issues with consumer SATA drives are:
1. Driver problems when put behind SAS interposer and expander.
2. Typically lacks supercapacitor for flushing write cache in power loss.
3. Very little overprovisioning.
4. Usually low life spans, unsuitable for 24/7 duty cycle.
Will I be fine to use consumer SATA drives on my ZFS server if I took these steps to mitigate the problems then?
1. Remove the SAS expander(s) on my server chassis and attach the SSDs directly to SAS HBAs internally (no separate head node and JBOD chassis) using SFF-8077 to 4x SATA fanout cables.
2. Use redundant power supplies and UPSes.
3. Partition the drive only to use 80% of actual storage space.
4. Get high MTBF drives, e.g. Samsung 840 Pro = 1.5 million hours MTBF.
The only problem I foresee with my setup is that it's a hassle to hot-swap and organize the drives if they are attached using fanout cables. I'll need a spacious chassis and it won't be densely populated. But I wouldn't mind doing this to avoid spending $5.5 per GB for SAS SSDs or stringing lots of 15K RPM SAS HDD three-way mirror vdevs.
Crucial M500 is obviously the most economical now, although I know the Samsung 840 Pro has a huge following - anyone using either on their ZFS servers?
