k1pp3r said:you really shouldn't have to worry about the conductivity, afterall, you have a steal or alluminum case don't you? But as whitewale said, work in a well ventelated area away from open flame or your computer. Only thing that comes to mind about the resin is that a on die phase change shouldn't get the carbon fiber that cold, but to watch for thermal expansion.
What exactly is the carbon fiber going to be used for ? the case?
Krazy_Joe said:The carbon fiber would be used to create an air-tight capsule for the cold plate in my kryotech unit. .
KoZLop said:mashie used carbon fiber for his mod.
whitewale said:Ok, you're going just the wrong way there. The fiber reinforced composite would be a rigid item, the cold plate another. Then you drop the temperature by some 60 C. The resulting thermal expansion mismatch will crack your resin in a heartbeat, or at least destroy your airtight seal. My suggestion would be a seal of neoprene or a similar low Tg rubber as an insulator/seal around your coldplate. You can use any GFRP (car grade from Walmart is fine) around that to give you a nice solid outer casing. But don't connect the GFRP directly to the cold plate, you won't be happy with the results.
