Using ASUS AI to Overclock
HRPC
AMD X2 3800
Corsair 3200 CL2 2-3-3-6 settings
Asus A8N-SLI Premium
BFG 7800 GT OC
So I am new to overclocking and having some trouble. I used Coolbits to get my card to where I want it to be BUT having no luck with OC my CPU\RAM.
When I increase the DRAM settings from 333 to 400mhz I get BSOD. The only thing that works is if I use ASUS AI OC at 10% which CPU-Z says I am running my chip at 2.2 and my RAM at 175...
I got modest performace increase and temps are below 60 but is this all I can do? Why does it appear my RAM will not accepts a 1:1 ratio..
First read this: http://hardforum.com/showthread.php?t=795444
Follow the steps to test your RAM stability first then move on to the proc. In the Bios, set the DRAM settings to manual and the speed to 400 mhz. THis is not what speed your memory will run, but rather the divider (DRAM/FSB) with 400mhz=1:1. Set HTT multi to 4x. Now use jumperless settings to adjust FSB and multiplier. YOu should be able to just follow the guide I linked up top from this point. Don't use the Asus AI to try to OC, it sucks. If you want to do anything from inside windows then use ClockGen.
^^^^ Agreed
Read the guide, learn about your BIOS settings and how to use them. You'll get a better overclock.
For reference, here are my settings to get my 3800 to 2.5Ghz:
CPU Frequency: 250
CPU Multiplier: x10
CPU voltage 1.4 volts
Memclock Index Value 333Mhz.
Hyper Transport Frequency: 4x
D3v01D said:
^^^^ Agreed
CPU Frequency: 250
CPU Multiplier: x10
Werd that's what i'm running too. My memory is at 208MHz which is nothing.
If you want to run your Ram at stock follow this
For reference, here are my settings to get my 3800 to 2.4Ghz:
CPU Frequency: 240
CPU Multiplier: x10
