I've got a 6700k in a Gigabyte z170 UD5 (See sig.)
My RAM is G.Skill F4-2400C-15D-32GVR; http://www.gskill.com/en/product/f4-2400c15d-32gvr
Each stick is 16GB. Each kit has 2x 16GB sticks, for 32GB total capacity...per kit.
I know it's recommended to use matched sticks for quad, but I had to stagger my buy, so I bought two of these kits, for a total of 4x 16GB sticks or 64GB total. The kits have identical specs (the same exact sku).
I've tested it with Memtest64+ and some other tests. It -seems- okay, but now a debug program for some software is showing that I've got some floating point math errors.
My rig has been at stock speeds (XMP profile for RAM, default speeds for cpu and gpu), and volts.
Can this memory be causing the floating point errors?
Thanks,
Ken
Thanks,
Ken
