SilentDoh!
- Feb 12, 2007
I have been wondering if you have something like the Corsair H50 CPU cooler and you wanted to get better performance out of the cooling system is it possible? (By better performance I am thinking cooling better) If it's possible could you do it by putting a higher RPM fan on the radiator or would you have to some how fit a physically bigger fan with some kind of funnel adapter to it? Like go from a 120mm fan to a 5" fan on your radiator.
