Using an existing Koolance block with a new WC setup?
Absolut Talent
Banned Ad Blocker
I have been running a Exos setup for the last 3 years and ive been happy with it.
I just recently upgraded my vid card to a Evga 8800 GTS and went with the Koolance 280 block for it. While doing some research on the block (the standoffs need to be filed down so it will fit this card) i was thinking of upgrading my WC setup. If I was to get a new rad, pump, CPU/NB blocks (thinking DD), could I still use this Koolance Gpu block with those new stuff with the copper internals?
im not to sure on the internal of the koolance block, thought it was gold plated
If it's gold, you should be fine, but a good way of preventing any corrosion is to isolate the copper components from the case.
If there is ANY metallic pathway between the copper parts and the aluminum parts (that conducts electricity) you'll get corrosion. Since the waterblocks are grounded to the case (through the chips they're cooling), it makes sense to isolate the rad from the case by using rubber washers and nylon screws.
As for a NB/SB block, try to get one that's the same composition as your CPU and GPU blocks, for good measure.
And always use 10% pentosin.
You'll be fine.
Yep, he hit the nail on the head. I prefer using Koolance fluid; you might lose ~1C performance but I like not having to worry about corrosion or biologics.
cool. thanks
I got some anti corrosion and biocide on the way with the other parts. Should be here tomorrow... but then I gotta wait for my Koolance GPU block to come back from an RMA. There was a small pinhole on the bottom in the grooves above the ram. I tried to pass water through it, and it seemed dry... but I figure send it back and get a new one just in case. Also i hope its a new revision that will fit the Evga cards (first run blocks had 1/16" too long standoffs, no contact with GPU)
