ElementBilly
- Sep 22, 2010
So last summer i bought an alienware aurora computer. My upgrade ability has been so limited I finally decided to buy a new case and psu. From everything I can tell it will work other then im not sure of how i will power my ram fan, cpu pump and case fans. This will be my first build and dont have alot of exsperience.
Can all case fans be powered straight through power supply?
From looking at the mobo I can see a power plug for cpu fan but the pump plugs into a separate card inside the case Im thinking just ditch their cooling and buy a Fan/heat sink of some sort.
Is it worth trying to use this Mobo or should i just buy another? id prefer to use it and save a little cash.
Heres some pic's of the board the fans plug into and the power cable of the board.
http://img530.imageshack.us/i/067ts.jpg
http://img202.imageshack.us/i/072yfa.jpg power cable of the board fans plug into
http://img413.imageshack.us/i/065on.jpgboard fans plug into
