shadowbreaker513
- Feb 15, 2005
Now that I'm home from college, I'm running into a problem that I never thought about before. We recently moved, and got FIOS, however, the modem/router thing they gave us, is in my grandmother's den downstairs, so everything I have has to be wireless. It's not possible to move it, and it's not possible to run cables, so I'm stuck to wireless. I did a bit of research, and I found that it's possible with some routers to use the router as a wireless bridge, so I could just plug my computer into the router and have that pick up the wireless signal. I did some research on my router (http://www.newegg.com/Product/Product.aspx?Item=N82E16833314022) and from what I've found, it seems like it would be possible to do it using that router, but everything I found, including that in the manual I found online, seems to be poorly written and hard to follow. Is it possible to use that router to connect to the pre-existing wireless network, and if so, will I be able to connect both my desktop and my Xbox360 to it without issue?
