Got a slight problem here. My MCP650 is too noisy to take naps with on and after 4 months, I've had it. I ordered a Noise Isolater 5.25" Fan controller to go with my new fan setup. I was thinking of hooking my 4pin MCP650 into a 3pin adapter, then running it to the fan controller so I can adjust it to full during the day, and slow it down at night.
The problem lies here. The pump takes 24Watts 2.0Amps at 12V full running. The controller's maximum is 20Watts 1.67Amps per channel. What will happen if I run it for days at maximum? Will the unit blow up? catch on fire? just malfunction quietly?
I may have found a solution to this but I need experts on this. The controller's max is 20Watts PER channel. There are 3 channels available. So what if I split the 4pin into TWO 3pin molexes, and run each to different channels. Will that be able to safely run my pump at its maximum for months without dying?
